xr50 forks bent?
i just put on a new set of starcrosses on my sons xr50 and noticed that the front tire is barely rubbing the right inside fork rubber dust seal,any suggestions on a easy fix? more annoying than anything but i thought someone else may have had this happen. :)
I bought a used crf 50 and the wheel was just about to rub on one side. I thought it was supposed to be this way. :D Then I decided this was not right and I took off the front wheel. The problem is that the forks are crushed at the bottom where the axel goes thru. What I did was put a long punch thru the axel hole on each fork and bend it one way or the other to make the wheel straight. Or maybe twist the fork around 180 degrees. :)
i just put on a new set of starcrosses.
What are Starcrosses? Anyways, The fork legs on these little buggers aren't even from side to side. Try this, With the front axle nut loose, align the wheel by pushing up on the longer fork leg (the side the top of wheel is leaning toward)to center the wheel between the fork legs. Then while holding it in position, tighten the nut to the specified torque. This should fix the problem. Good luck!
michelin starcrosses and thanx -im gonna give it a try this evening
i agree with you about the fork shafts being uneven,but pushing up on one side then tightning doesn't work-it just returns when i quit pushing that side up.i haven't tore into to these forks yet and i was wondering if there is somthing internal that could be damaged ?the forks don,t appear to be bent just uneven. :)
Ok, how bout this one...
My son has a 2003 xr50, and his forks are both bent slightly backwards toward the engine head (an unexpected collision with a railroad tie). It's still quite rideable, it just shortened the front-end rake, but it just doesn't look right. Any one have an idea (or experience) on how to fix this? :)
Dan
We had this same problem. My daughter and her husband bought a '97 Z50 for my grandson. One side was slightly bent and the other side bent much worse. I took the lower legs out and using a rubber mallet and a couple of wooden blocks, to support the ends, was able to "persuade" the legs straight. The rubber mallet left no marks on the chrome. It just takes a little patience and the willingness to beat the crap out of something with a rubber mallet! Great stress reliever! :)
  • Similar Content
    • By Boondock Patrol
      Hello friends. We added a 2007 Honda CRF70F to the fleet, and here is a video introduction of the bike. I know it's simple, but I'm proud of it, and we are already enjoying it very much. What a cool little bike.
      Hello friends,
      I've seen much debate on which motor oil is best for the mini bikes. I decided to go ahead - having had great experience with Pro Honda HP4S synthetic oil in previous machines - and try it on our 2007 Honda CRF70F. So far, I can already say that the transmission seems to shift smoother and more quietly. And call me crazy, but kicking it over it feels like it has more compression than before??? It's running fantastic since the change and doesn't seem adversely affected in any way...yet. Anyhow, I threw a little video together of the process while I was teaching my boy how it's done.
      Hello friends,
      It's been two weeks now since we purchased our 2007 Honda CRF50F, and my 8-year-old has really taken to it. I'm so impressed how he can run the whole show himself, from getting it out of the garage, to starting it up (ignition, fuel, choke and all, correctly) and putting it away when he's done. He has also impressed me with his comprehension of the gearing, and knowing when to shift. Here's a short video of him in action from this afternoon.
      Hello friends. I'm new here because I've been riding quads for the past decade. However, in this area (NE Arizona) everybody rides dirt bikes. So, I decided to swap to dirt bikes. I've got 4 young kids, so one week ago I found a pristine little 2007 CRF50F for sale in Flagstaff, and talked the original owner down from $1200 to $1000. I picked it up, and the dirt biking days have begun! I already picked up a Ricochet brand skid plate for it that I will be installing soon.
    • By Kawasaki100
      I have a 04 crf 50 that was made into a pit bike and I need help figuring out what it is. I have no idea if it’s a 70 head or 50 head the cylinder says 72cm3 which obviously means it’s got a 70 cylinder for sure. Needing to know for gasket and ring sizes. Thanks!
