Quick mpg check
Hey guys
I have a 2012 Australian  400e in  derestricted form
Airbox opened up and pipe baffles removed but otherwise stock standard.
I'm getting 20 klms / litre  (47.3 mpg)  with on road use not racing it much at all
Does that sound about right??
cheers
14  47 gearing  btw
Yes, that sounds about right....What tyres are you using?, as with gearing and jetting, will have a significant effect on fuel consumption ...
I have 15/43T on my big bore E....
Over 135 kms  it used 6 litres with pirelli MT90 A/T tyres,  knobbys (dunlop 606) was using 7 litres......
Changed out the needle from OCEMN to OCEMP (leaner) and now only using 4.5 litres over the same 135 km circuit.
Edited by Craigo 485sm
pirelli scorpion xc mid hards
I got it primarily for off roading and the occasional work hack , but I'm riding it everyday to work now.   (Perth traffic sucks and it takes it out of the equation :thumbsup: )
47.3 sounds about right.  I was averaging a little over 50mpg on my all stock '13 Smodel. I just did the 3x3 and rejet so I assume I'll lose a little MPG, but gain a few SmilesPerGallon ;)
Yep, I get around 50mpg.
My last ride I got 49mpg......the one before 41.......still making calculations to come up with an honest average. My mileage drop came after the BB kit, cams and carb change, but I'm guessing at looking at the other people who have posted and what their bikes have, this is probably pretty close now.
Sounds about right - Used to get about 45mpg (US gallons) on a stock DRZ; I then had it modified
slightly, rejetted and dynoed it. Reduced gearing. I get about 35mpg now - BUT because the engine
is running so much better - I ride it a lot harder which reduces the fuel consumption
Gerry
I've got MRD SSW corked, stock tank, stock gearing, stock airbox, K&N, haven't jetted, and hammer pretty much everywhere I go and get about 50-55 miles before I have to flip on reserve. :cry:
I'm sure it has to do to the fact that I HAMMER the throttle from stop sign to stop sign, I average 38mpg, but I'm smiling the whole time :ride:
I guess I don't ride very hard compared to everyone else. Mine has 3x3, rejet and a Big Gun exhaust (came with the bike, I am planning on getting an MRD once spring gets closer) and I think my worst tank all summer was 53 mpg. My best was 64 mpg.
Something is not right there at ALL!   25mpg...     + you should really rejet and do the 3x3 mod,  your bike will run much better.
Yeh, that's not unreasonable at all....I used to get very similar mileage when I had just the 3x3, jetting and full Yosh exhaust.
Drop in the big bore, cams and CVK40mm carb, twist the wrist alllottttttttt more, and we're down to 41. hahahahaha, YEH, it was worth it!!   :smirk:
