nology coil
Can I use a 0.6 ohm coil on my 86 cr250r which has a 0.3 ohm system. Nology says it should work up to 10k rpm. Bike peaks <9k. I've got an 87 cdi which is a 0.6 system. Thanks
Not sure. If its not expensive,maybe try it? What if you ise cdi and spark plug that 87 uses. Other thing to consider is ignition timimg. .6ohm should just have a cooler spark than a .3ohm ...i think?
I was under impression oem wasnt readily available.
