KX fork conversion
Check out the Kawi 2 stroke section and the threads on how we change the KDX forks to USDs, I would say the process is roughly the same. Be sure and do some measuring on the fork legs your planning on swapping onto it as the lengths may be quite a bit different (or not). Example being, the '97 KX125 fork legs I used on my KDX needed to be shortened a full 2" to get the same suspension balance and geometry as stock. Also clamp/stem/head tube compatibility issues to overcome. With proper research and homework, I figure it can be done, but it's far from a bolt on deal.
Edited by OLHILLBILLY
