2001 wr250f water pump housing hole leaks coolant.
I recently bought a 2001 wr250f and noticed there is a coolant leak under the pump looks like it's coming from the hole. I have pulled off the pump housing but looks okay. I am not sure which parts I need to replace. I need help and would appreciate it.
Water pump is stuffed.
The seals on the water pump shaft are done.
That's what that hole is there for.
