Single ring piston
Has anybody used a wiseco single ring piston in a 92-01 cr250? Debating using one in my 01. I've searched everywhere and can't find much info pertaining to CR's. Thanks for any info
I had a 1996 cr 250 2 years ago and that's what I used. It worked fine with no issues... No holes needed to be drilled either. I just used the standard wiseco piston, nothin fancy. Give it a shot
I was looking at the racers choice gp piston. I race hare scrambles, don't want to lose any bottom end power. I know its kind of for high revvers.
Well I can't say for sure if it'll effect anything besides your pocket but the gp piston I believe has 2 holes in the front of it to let the pressure built up from behind the piston out, and I do believe that's the same type of piston Jeremy mcgrath used for his 96 but I'm not 100% sure of what effects it'll have... I'd say try it and find out would be the only sure fire way... I've never used anything but a single ring piston and I had flywheel weight in my bike and I only rode trails and I've never kept it highly revved, nor fouled a spark plug... Not sure if this helps any but if you got anymore question, shoot em up and I'll try to give my best input for you
I've seen some pictures of it, don't think it has holes in it. But it may. Guess I'll find out, going to give it a try I think just for the heck of it. Unless somebody chimes in against it. I figure I'll probably have to put a ring on it sooner than the two ring pro lites, but that really isn't an issue I like to clean my powervalve throughout the season
Well if you perform maintainance that well on your bike, I could almost guarentee that you'll be happy with it
Just an update on this if anyone is curious. I put a single ring racers choice in my 01 cr250. Got to ride it today.
It was super muddy and spots with snow and ice, so I had a hard time really getting a feel for the power. But the bike felt great. Didn't have my flywheel weight on, which I always do but didn't put it on yet after a new bottom end , but I didn't feel any loss in low end power like I read that I might.
The one thing that is definitely noticeable, is how much easier it is to kick over. Compared to the usual 2 ring pro lite that I usually run, it feels like kicking over a 125. Don't know if that's good it bad.
But the bike definitely rips. I'll add more when I get to ride again in better conditions.
Can anybody comment on the single ring being easier to kick? It is starting to have me worried that something is wrong.
Rode my buddies kx250 this weekend, and it was twice as hard to kick as mine, and that's how mine felt with the 2 ring piston.
On my '05 w/ a single ring, i don't find that it's all that easy to kick over when I have a fresh top end. I have to put all my weight down on the kicker if I want the kick lever to go all the way down and make contact w/ the footpeg.
Did you do a compression test at any point before or after rebuilds? What is it pushing now?
My 2000 put out 210 with a unbroken in double ring wiseco and stock jug/head. It's at 218 PSI now after 104 hours.
I did a compression test with a cheap $20 tester. Got 165, which also has me worried. But it runs great, I'm half tempted to take the cylinder off and inspect everything and put a new ring on it.
I just don't see what I could have did wrong. I had the cylinder replated, and put a single ring in it and broke it in as I normally would. Piston clearance was fine, on the tight side but ok.
Did you hold the throttle wide open during the test and kick it hard 5 times or more?
Yes. Only thing was I've heard you should do it with a warm engine, which I didn't do
Well I went riding Saturday. Came to the conclusion something is definitely wrong. It has decent top end power, but lacking considerably down low. Powervalve seems to functioning properly.
Going to put a new ring on it this weekend, hopefully it cures this problem. Just really disappointing, have way too much money in this bike.
Tore it apart last night. Ring was toast. That would explain the issues. It had close to an 1/8 inch of ring end gap. Seriously. I'm surprised it even ran. New ring on, would have liked to spent more time deglazing the cylinder, but racing tomorrow and was just happy to get it going. Now the question is, why, after only 8 hours on this ring, did it wear so bad?
single rings are for no compromise power in a race bike.
Single ring pistons have no real use in our bikes, anything less than a expert class racers at lorettas is better suited by a 2 ring piston. Lasts longer, better lowend power with less piston rocking in the bore.
That may be true. However, the 05-07 CR's come with single rings. Its a very popular mod on yz's. Thought I'd give it a shot, there really is no info on it for these bikes.
FWIW....I get 80-85 hrs use on my single ring... previously w/ a Wiseco ($23), now on NAMURA ring ($12).
General off road riding only, 44:1, Klotz techniplate.
Next piston change, however, I'm going to try the high dollar Wossner 2 ring piston set . Hope I see this 2 ringer go past 160 hrs.
KTM owners seem to be getting 200, even 300 hrs on theirs.
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
