Replacing left side crank seal
I'm pretty sure I need to replace the left side/flywheel crank seal on my 2005 200 exc. Can I do it with the engine in the bike?
market are you sure crank seals cant be removed with the motor in the bike? I never done 200 seals but with Honda's and others I just removed the clutch and outer things etc to get at the outer center case seal then pulled it and replaced it
This is a super easy job. You'll need a flywheel puller, stator cover gasket, crank seal, and a wood screw to get the seal out. It might take you an hour if you are slow. Just lean the bike over and take it apart.
  • Like 2
