longer chain to lengthen swingarm
[ 08 450r ]   I have 1/2" in of threads showing on my chain adjuster. Want to push back swingarm 3/8" which should leave 1/8" for adjustment before needing to remove a link. Chain is 116 links now. How do I figure out if I need 118, 120 122, etc. links on a new chain to put swingarm back 3/8"??
On another note there is a train leaving New York city traveling 60 mph and a train leaving Chicago traveling 40 mph.................
So you are sure going from 116 links to 120 links will be more than enough chain?
On another note, I have a 98 380SX.
After you've lengthened the swingarm, install the longest chain you have and have it meet on the rear sprocket, then you'll know how long of a chain you will need so you can buy the correct-length new chain. If you lengthen the swingarm more than a mere 1.25" you will likely need longer than a 120 link chain!!!! Of course sprocket size will factor into the equation, too, so put the proper size rear sprocket on when checking... Each chain link is only 5/8" long on a 520, so it's fairly easy to calculate how many link you'll need if you know exactly how far rearward you move the rear axle.
Edited by Eddie8v
Thanx Eddie, I knew there was a simple way of figuring that out that i couldn't think of.  That's why I like this [and other sites] so much. Good people with great ideas and experience to solve problems.
And again thanx for posting the info a few years ago about how to properly jet an 08 450R at 5000 ft. I would have been chasing that jetting forever.
You can use two masterlinks for a small section of chain, if you want too.
I used to take a small section of chain in and out so I could change from single track to desert handling.
Not enough difference for that hassle, I concluded. Sag and clickers were much more influential on the handling than rear axle position.
Edited by TheKoolAidMadeMeSick
Here's a useful tidbit of info regarding chains.
a 520 chain measures like this.
All the numbers correspond to 1/8" increments.
5= 5/8" pitch, distance between the roller centers.
20 is actually 2.0 and means 2/8" wide rollers
A 525 would be same pitch, but the width of the rollers is 2.5 (or 5/16" .3125)eighths wide
So if you wanted to move the wheel back by 3/8's, you'd need to add 6/8's right? Problem there, can you see it?
There's a reason why gearing and chain length etc can see almost random unless you dive into the mind numbing details.
