Bar risers / high bars
So I am very tall and am wondering if I can put a 30mm bar riser and high bars without having to get longer cables if any one has experience with the 14 kx 250F and high bars/bar risers please comment I would like to hear what you have to say.
Thanks for your time
Happy riding
Edited by motomike81
Try learn to ride with the standard bars or at the minimum go a slightly higher bend, the bike works better especially cornering with standard height bars.
Im 6'4 and bar risers threw everything off...Renthal Carmichael bends and the pro taper windhams are perfect
Im 6'3 and chose to just go with the windham bars and found that worked nicely
I am almost 6'7" so your points are very valid but even with tall bars I am bending over to much and I am looking to try out high bars and bar risers if it works and I feel comfertable then great but I don't want to spend the money on bar risers to find the cables don't reach if I don't feel comfortable I can take them off and could throw them on one of my pit bike or just accept it as a loss
Thanks for all you thoughts I will take them into consideration
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
