XR 400 tune-up done, but now help needed to dial it in.
Last week, I picked up a '01 XR400 and after absorbing all the best known methods here on TT -- I tore into it today to give it a once over.  My objective was to check the "gordon mods" and to perform the usual maintenance.  I did verify that the exhaust port, aftermarket can and desnorkling was done.
I feel good about all of the steps I've performed, but I'm having some hot running issues that I'd like to see if I can get some pointers.  But first, I'll give the set-up.  When I picked up the bike, it ran well - started OK (I wanted it to be better).
Here's a list of what I did:
  • Replaced filter with Uni filter (oiled it up first)
  • Adjusted the valves.  I think the right term is they were "tight" as the feeler gauge would not go into the gap.  Adjusted them to 0.004 intake and 0.005 exhaust.
  • Pulled the carb, did a minor cleaning (very little varnish present in the bowl) - replaced the existing jets (148/55) with (160/60).
  • Replaced Air/Fuel screw with Kouba FS-3 adjustable screw (turned out the suggested 1 1/4 turns per Kouba's instructions (the screw I took out was at 1 7/8)
  • Replaced spark plug (existing was fouled rich) with Denso IX24 plug
  • Changed oil / filter and cleaned screen.
  • Installed K&N fuel filter.
  • Used new fuel (premium - no ethanol)
When I was done, it cold started fine, ran fine.  Took it for a spin in the snow.
Here is where I think I screwed things up.  I started to follow Kouba's instructions on dialing in the air/fuel.  This was done by bringing down the idle speed and then going -in / out on the air/fuel screw to find the middle between just about stalling on both ends.  In hindsight, I think I did this too soon (engine not yet at the right temp).
Here's my problem and what steps I took:
  • It was running fine at 1/2 choke (normal idle speed, etc) - then when moved to choke off, it would die
  • Here I adjusted the idle screw to increase idle.
  • Now 1/2 choke was still fast idle, but would still die when choke was "off"
  • Increased idle screw more, but I noticed it would not "hot start" without 1/2 choke.
  • At this point, I increased the idle speed screw even more and it would hold idle at choke off (albiet too slow and rough)
This is my first dirt bike and I'm a total novice with regards to carburation, etc.
Suggestions?  Thanks in advance.
What is your elevation? I'm guessing it's pretty cold there if you're riding in snow. Humidity is a factor too.
I prefer to set my fuel screw with the idle speed set at where I am ultimately going to want it, not like you've done. You'll have better throttle response off idle and easier starting if you'll run a little higher idle speed. The trade off is that you'll have less engine braking when letting off the throttle when riding, but depending on what terrain you ride and your experience and speed, less engine braking can be a good thing. The bike will keep its momentum like a 2 stroke bike does when letting off the throttle.
I tune my idle speed to give me the specific amount of engine braking I want at the time and for the terrain I'm riding.
2 turns out on the fuel screw is the sweet spot you're aiming for when jetting/tuning the pilot circuit for best idle and throttle response, with 1.5 - 3 turns out being the acceptable range for a specific pilot jet before needing to change it.
Assuming the Kouba fuel screw taper is the same as the stock one, we around here always suggest starting your fuel screw tuning at 2 turns out and fine tune from there for best idle and throttle response off idle, on the rich side. That means, when starting at two turns out, with the bike at the proper warmed up temp, come out slowly with the screw until the idle begins to drop, stop there and begin to turn it back in slowly and stop at the point where the idle speed increases again. That's very close to best idle "on the rich side".
If you were to do the opposite, turn the screw IN and then back to best idle, that would be best idle on the "lean side". The fuel screw meters fuel. OUT is more fuel/ richer and IN is less fuel/ leaner.
When you replaced the fuel screw with the Kouba part, did it come with a small washer and o ring too? When you pulled the stock screw out, you should have had a spring, small washer and o ring come out with it. If not, you need to account for those parts. They are either still in the bore or weren't there to begin with. The new Kouba part also needs those. The spring goes on the screw first, then washer, then o ring, then you slide the whole assembly into the bore. Screw it in til it "lightly" seats, then back out 2 turns.
Be sure you're using the choke lever correctly. All the way down is choke off. All the way up is full choke. If you have that backwards in your thinking, you'll never get it to run right.
Well - turns out I was going the wrong way with the choke - DOH!  Once I corrected for this mistake, all is well in the world.  I was able to tune in the Kouba part and adjust to the mid-point between the lean turn-in "fall off" and the rich turn-out "fall off".
Good info on the idle speed and I wanted to answer about the Kouba part assy.  When I took out the stock air/fuel part, the spring and washer came out with it (btw - kouba doesn't provide these parts and need to reuse OEM).  I could see the O-ring, but it didn't come out on it's own.  Since I didn't have a replacement and to risk buggering it up using a pick to take it out, I just left it there and reassembled the Kouba part with the sequence of new screw, spring, washer, and by default, the o-ring already in the carb.  The shape of the Kouba part is a little different as it's more tapered at the part where the needle meets the main body.
My elevation at the house is 650 ft and it was below freezing yesterday and a little above freezing today.  Work is being done in a heated garage, so around 45F with the door slightly open.  My riding will be mostly around 1000-2000 ft.  I'll keep the 160/60 jet combo in the stock carb for now and see how it behaves.
I'll bet that jetting works great. And you are FAR from the first who has got the choke position wrong. Very common mistake.
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
