KLX and KX?
Can anyone tell me which KX graphis will fit a KLX? Any of them...forks even?
Forks graphics will fit,you can run an 06/08 KX  rear fender(bolts straight up to klx) and use those graphics,front fender graphics will fit(06/08 KX),radiator shrouds you can run 06/08 KX shrouds but one bolt will not be able to be used or run one of the larger tanks which require KX shrouds anyway,side plates will not fit perfectly unless you do a full airbox and side plate swap with 06/08 KX,otherwise you could use them anyway but it will not line up properly on the side plates and airbox door etc.
