2010 CRF 250 won't kick when warm
Hi I'm new to this forum, new to four strokes and new to fuel injection so hoping someone can help me out. I've recently bought a 2010 crf 250 it starts first few kicks when cold and runs lovely, but it won't kick over after I've warmed it up and have to bump it and again runs lovely after a bump, the parts I've changed are:
Spark plug
Fuel filter
Coil lead
The valve clearances have been checked and valves re shimmed and then rechecked again after a ride
Timing checked and is ok
All plugs have been pulled apart and cleaned.
Tried a technique which I was told about for when shutting off, where by you blip the throttle 3 times before hitting the kill switch.
All this and I'm still in the same place as when I started, really stuck as to where to go from here, any help with where to go from here would be much appreciated.
You probably have already done this at some point, but have you played with the idle. I know with my 2010, playing with the idle adjuster makes it easier to start at different engine temps.
I have a 13 and it has the same problem some guy at the Honda dealer told me hold the throttle in all the way at the same time give it 3-5 slow kicks then release the throttle all the way in and kick it 1-2 times and it should start.
It always works for my 2013.
Yeah I've tried doing that as well, thanks though, I've put this post on here twice by mistake, think in two different sections. Someone has suggested that I perform a leak down check, says it could be due to a slightly burned exhaust valve or a worn/misshaped valve seat. A friend of mine has a leak down tester that I'll be able to borrow, so this will be my next step. I'll let you know how it checks out.
I've also tried giving it slow kicks then going for it, but she still doesn't want to go, never with the throttle open though. I don't know why holding he throttle open would help on the fuel injection, but I'll give it a go anyway, cheers dirtman48
Just gave this technique a go but had no luck. Was hoping it would work and save me a lot of time. Thanks anyway, my next step will be a leak down test that someone has already suggested
Sorry man.
Could be your coil is on its way out, or the fuel pump, or maybe the condensor.
Right got another problem now as well as the starting issue, so, gave the bike to someone who has had motocross and enduro bikes for years to have a look at. He wanted to try and find out if it was a fueling problem, said the fuel pump seems to be working fine. Part of his process was to take the air filter off and spray fuel down the intake and kick stat the bike. He said that it started no problem even after being warmed up, but all of a sudden when he was doing this the bike started to idle high and the revs won't come down, adjusting the idle screw doesn't make a difference to the revs, but if you pull the idle screw out the bike does rev faster. When started the MIL comes on and goes off as it should without giving a code. Anyone got any idea why this would be?
Edited by jamesturler
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
