DRZ 400E rear shock spring
  Hey guys, My 2003 400E rear shock has a red spring, however I have seen a few with a yellow spring.  Is there any differance?
most likly aftermarket, i had a red spring, now i have a factory connection rear spring
i think the red springs are either eibach, my factory connection rear spring just went in and it is yellow.
I have a spring on order from Eddie, I am just wondering if I am wasting my money if I already have a after market spring.
On a seperate note I was thinking of the lowerin kit placed on my bike.  I read that lowering the rear makes the spring and shock not perform as well.
Colour makes no difference
There were red and yellow IIRC from suzuki
E model's are 5.3kg/mm and S models are 5.5kg/mm irresepctive of colour
Aftermarket springs usually have the manufacturers name on it
If its plain, with no makrings then probably an OE spring
Yeah I've seen red, yellow & white OE springs... only way to know is if it has any markings or have a suspension shop check the spring rate.  Either way, try setting your rear race sag and then go by the static sag to determine if the spring is right for your weight.
Ok, perfect.  Thank you.
I had red before my racetech spring which is blue.
