CRF 250 won't kick over after being warmed up
Hi I'm new to this forum, new to four strokes and new to fuel injection so hoping someone can help me out. I've recently bought a 2010 crf 250 it starts first few kicks when cold and runs lovely, but it won't kick over after I've warmed it up and have to bump it and again runs lovely after a bump, the parts I've changed are:
Spark plug
Fuel filter
Coil lead
The valve clearances have been checked and valves re shimmed and then rechecked again after a ride
Timing checked and is ok
All plugs have been pulled apart and cleaned.
Tried a technique which I was told about for when shutting off, where by you blip the throttle 3 times before hitting the kill switch.
All this and I'm still in the same place as when I started, really stuck as to where to go from here, any help with where to go from here would be much appreciated.
Let's work on your terminology. 'Kicking over' the engine is your foot, pushing the kickstart lever down. So when you say it won't kick over you are saying the kick lever is seized in the cases or the piston is seized in the cylinder, etc.
But from your description, it seems as though you are saying that the engine DOES kick over but won't start when you are kicking it over warm. This is a classic symptom of a leaking exhaust valve- hard to start warm, needs pullstart and then runs well. Typically caused by tight valve adjustment.
You need to do a 'cylinder leakdown' test to see if you have a slightly burned valve or worn/misshapen valve seat which is in this area, I suspect.
Hi Sandlvr69, ok sorry, yes what I should have said was that it won't kick start once it's warm. When I checked the valve the exhaust valve clearance was on the high side of the tolerance for valve clearance but still in spec, 0.012".
Is the leak test something I can do easily myself and will I need specialist equipment? I'm trying to build up the equipment that I'll need to service the bike and do all the various checks myself, rather than have to rely on someone else. And also is a pretty easy fix if this does turn out I be the problem?
You need a cylinder leak detector for this test, they are somewhat expensive at around $200 USD. Your local bike shop will have one and should perform this test quite reasonably. You could provide access by removing the tank and etc. before taking to shop.
If your piston is old or of unknown hours you should replace it as a matter of course. You can then inspect the cylinder head.
Cylinder head and piston replacement is very straightforward on the CRF250 but rebuilding of the head is best left to a professional, too many tools required. Stainless aftermarket valves are a good idea for future longevity and complete aftermarket heads can be purchased for just a bit more than having the old one rebuilt.
Of course, ebay usually has used cylinder heads for sale much cheaper. I scored a stock head for my 06 CRF450R for less than $100 USD and it looked like brand new when disassembled, maybe 10 hours on it.
The piston was replaced and the engine rebuilt before I bought the bike, it's done about 15hours since. I've found out how to perform the test it seems pretty simple, I've also spoken to a friend who has a leak down tester but I'm going to have to wait a day or two to get it from him, as he's away. So I'll perform the test as soon as I get it off him and let you know how I get on. If I do find that this is the problem and I know it would have to be done correctly but is it just a case of replacing the valves? I've also be told about titanium valves, is there any point in fitting these or wouldn't I see any difference? I want to eventually tune the bike and intend on keeping it for a good while.
Ok, so at least you don't have a tired piston also. It's hard to recommend a repair when you aren't sure of the engine's state. So now I'd like to know if they just replaced the piston (which is the most common) or split cases, etc. Did they attempt a poor head repair as well? It's moot until you have checked leakdown.
Stainless valves are the way to go for longevity. Titanium valves rely upon a coating to prevent rapid wear and Honda had a problem with this for a few years which badly hurt their reputation.
To rebuild the head, you need to grind the seats and check fitment or replace the guides and seals. Stainless valves come with heavier springs.
People DO just install a new valve without fitting it properly and it never lasts long.
I believe it was more than just a piston and ring change, he did show me the parts that were changed, can't remember off the top of my head but I'll try to find out.
On top of this I've got another problem now as well as the starting issue, so, gave the bike to someone who has had motocross and enduro bikes for years to have a look at. He wanted to try and find out if it was a fueling problem, said the fuel pump seems to be working fine. Part of his process was to take the air filter off and spray fuel down the intake and kick stat the bike. He said that it started no problem even after being warmed up, but all of a sudden when he was doing this the bike started to idle high and the revs won't come down, adjusting the idle screw doesn't make a difference to the revs, but if you pull the idle screw out the bike does rev faster. When started the MIL comes on and goes off as it should without giving a code. Anyone got any idea why this would be?
The 2010's had a lot of problems with the fuel pump.  The filter would solve the problem but if not we would replace the pump.  I would try and swap tanks with someone that has a good running bike.  After starting the pump would slowly loose pressure.  An engine in poor condition, IE low compression usually won't start easy when cold or hot unless the valves are near zero clearance.  We always start troubleshooting with a leak down test first and then for correct valve lash to determine engine condition.  The Motion Pro leak tester works good on bikes.  I think we sell it for $150. You may want to check your heat sensor but we haven't seen any of those fail.  See if the throttle position sensor has been moved.  As far as ignition problems its usually the stator in most MX bikes.  They have a tendency to give a weak or no spark when hot.  I haven't seen this on the EFI models.
Thanks fastheads, The filter has been changed but it made no difference at all. The next step I intend on carrying out is the leak teat, what do you mean by valve lash and where is the heat sensor could this be anything to do with the starting issue or is it the high idling issue that you are speaking about?
Edited by jamesturler
Ok so I carried out the leak down test. The gauge showed that I had 80% cylinder leakage, weather this gauge is reading right or not I don't know but I could here air escaping from somewhere.
First I carried out the test on a cold engine at TDC, the compressor cut out when the gauge was reading 40%, I then read through the instructions again and it said to warm the engine to operation temp.
So this time I warmed the engine up, removed the spark plug and rocker cover, set it to TDC and tried again and got a reading of 80% cylinder leakage. I was able to hear air escaping from the top of the engine but not sure where from.
Well, that's not good if you set it up right...
Hell no, I checked for leaks on all of the joints but couldn't find any, read everything a few times:
Fit pipe and fitting to spark plug hole
Adjust the regulator all the way anti-clockwise
Connect the air line to gauge
Set gauge to zero
Connect pipe from the spark plug hole to gauge
Watch where the gauge comes to rest
Seems pretty straight forward
Ok so after last nights leak down test I thought that I must have done something wrong, so I've checked everything and done it again (a few times), this time with a cold engine and I got readings about 7%, if what I've seen is right this is good. So I'm wondering where I go from here and if there is anyway of checking that the pump is in good working order before ordering a new one, I don't know anyone with the same bike, so I'm afraid that swapping tanks with someone is not an option.ImageUploadedByThumper Talk1392394808.805840.jpg
7% is excellent. Your earlier readings may not have been made at TDC?
Mechanic's basic 101 philosophy is to check frome easiest to hardest, most likely to least, etc. In your our case that was cyl. leakdown first. Next I'd check for good, clean, blue spark with the engine at it's hardest starting mode (warm). I'd use a new plug, removed from engine.
Ok so finally got a chance to get back and do more, went to check the spark today but I wasn't able to start and warm up the bike, I had a friend check the spark whilst I kicked it over, it wasn't consistent.
1st kick= 1spark 2nd= no spark 3rd= 1spark 4= no spark 5= no spark 6= no spark 7= spark
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
    • By Throttlejockey
      Please post pics only. All other posts will be deleted so it doesn't get out of hand. PM the poster for more info or create a post.
      Violators will get a one day ban from the forum.
    • By bull413
      I checked the valve clearance on my 06 crf250r and both exhaust valves is at .007 and the intake is (left side) .005 and (right side) .000??? idk my feeler gague only went down to .002 and it would not slide in.
      Is that ok for the exhaust? Do I need to just shim the right side on the intake? or does both need shimming?
