Stage 1 hot cam for crf450
Hey guys I'm thinking about getting a cam for my 450. I do a lot of trail riding so the stage one seems to be the best choice what do you guys think? Am I going to feel a big difference or is it a waist of money?
I say a stage one cam, a recluse slipper clutch and bigger rads if it ever overheats. And a 13.5 piston if you ever want more power
Stage one is less power than stock, and the power stops at about 7k
I have a super cooler water pump, trail tech stator and head light heavier flywheel and electric fan so it doesn't get hot. I like lots of torque
Stage one cam and 13.5 piston will give you all the torque you can handle.
I havent seen that. The power is about the same, just lower in the RPM range. While it doesnt pull to the moon like a stock cam does, it doesnt fall off the map either. For a trail bike, its a good cam.
