Compress check readings
What is the reccomended compression readings for a yz250 . Mine is reading 150 psi it has 40hrs of racing on the hour meter.
What year?
That's really low for the newer ones. 220+ psi is healthy for them.
  • Like 2
09 I forgot to hold the throttle wide open maybe that is the reason the reading is low
Definitely. Repeat with throttle WOT. I did this to prove a point before, compression was 120 psi at idle, 195 psi when held WOT.
