cable choke question
I just bought a chinese 250cc bike for friends to ride when they come by.  I'm replacing the carb on it but not quite sure how that will affect the cable choke.  Specifically, I want to know if the cable that is on the handle bars can be used with a different carb.  When I took the existing carb off the choke assembly was easy to remove but i'm not sure if I just attach the cable to new carb or if i need to use the assembly that came off the old carb.  This is my first time messing with carburetors so it's a little confusing.  The carburetor i bought is for a cable choke.  Any help would be much appreciated.  Thanks guys
It was probably moved to here because it is a Chinese bike, and most assuredly has a Chinese carb on it. The Chinese carbs may LOOK like a Keihin or Mikuni, but that is where the similarities end. 99.99% of the time, the jets and/or parts are not interchangable.
To answer your question, if you want to use the choke cable on the bars, you have to buy a compatible carb with the same choke mount setup, in order for the cable to mount to the carb. An alternative is putting a carb with a manual choke lever or plunger you can easily access from the left side of the bike.
That's why I don't run this site lol, thanks.  I wasn't sure if the new carb would come with the mount or if i had to remove the old one and switch it over to the new one.  Thanks for clearing that up.
When it comes to the Chinese parts, you have to play the Match Game with the parts you have. There are a few websites for Parts where they have good illustrations for you to match your parts up.
http://get2itparts.com/index.php?main_page=index&cPath=1085_2110_114300
http://www.buyatvsonline.com/chinese-carburetors-150cc-250cc-carbs-c-279_802.html
http://www.partsforscooters.com/Dirt-Bikes-Parts/Dirt-Bike-Carburetors-and-Parts
