FCR kit...Pre-purchase advice.
I'm hours away from making the FCR dream a reality.  Want to verify settings and looking for tips on where to buy needed parts.
I'm running a stock S with a full yosh and a 3x3.  I usually ride at 3000-6000 ft (4000-5000 most times).  Low humidity with winter riding temps in the 40s and Summer in the 80s.   If I am not mistaken, I need to be running the EMP needle as opposed to the EMN?  Also, most likely a 150 main?  I would like to know the best spot/price to pick up the needle and jet.  Looking to avoid dropping an addt'l $72+ on a jet kit if I don't have to.
Holler back!  Thanks!
Seriously, 1371 posts and you still have to ask?
Thanks for the helpful response!
Well documented here that all you need in the way of jets and needles can be purchased from, http://www.jetsrus.com/,http://www.sudco.com/
Also well documented that Eddie will spec your carb for your elevation and bike setup.
Also documented what jets and needle the TT FCR kit comes with.
Hence my helpful response, if it was just a needle and MJ question I would not have responded that way as elevation can complicate things.
DRZ400 FCR39MX Jetting for: sea level, stock exhaust or quiet 96db aftermarket pipe, 3×3 Mod
  • 155 main jet
  • 200 main air jet
  • EMN needle
  • clip 3
  • 45 pilot jet
  • remove pilot air jet
  • 2 turns fuel screw
  • o-ring mod
DRZ400 FCR39MX Jetting for: sea level,aftermarket pipe with open muffler
  • 160 main jet
  • 200 main air jet
  • EMN needle
  • clip 3
  • 45 pilot jet
  • o-ring mod
DRZ400 FCR39MX Jetting for: 4000-600ft, stock exhaust or quiet 96db aftermarket pipe, 3×3 Mod
  • 145 main jet
  • 200 main air jet
  • EMP needle
  • clip 3
  • 45 pilot jet
  • o-ring mod
DRZ400 FCR39MX Jetting for: 4000-6000ft,aftermarket pipe with open muffler
  • 150 main jet
  • 200 main air jet
  • EMP needle
  • clip 3
  • 45 pilot jet
  • o-ring mod
Good choice on the FCR
Ok, I will play....
EMP needle , clip 3
155 main jet with open pipe, 150 mj corked
Jet kit not required....I am not sure what needle comes in the TT kit, you may be able to request the emp needle upon TT shop purchase via email..
Also get the R & D Racing Products Flex-Jet Remote Fuel Screw
Edited by Craigo 485sm
Plus one
Thanks guys.  I saw the post in "The Bible" regarding jetting.  Just wanted to see if there was a big difference in opinion and make sure I got close on my first try.  Biggest question was on where to get parts.  I can't wait!
I assume this is the EMP I'm looking for?  http://www.jetsrus.com/individual_parts/017_264_su.html  And the Jet page... http://www.jetsrus.com/a_jets_by_carburetor_type/jets_keihin_99101-357_main_Hex_25-xxx.htm
I'm running an older (2005ish) Yosh RS3 with the longer spark arrestor (not the free-flowing dome screen).  Is that considered a "quiet" or "Restricted" core?  That pipe sure ain't quiet!  I see they offer a 152 as well...
The links are correct, use genuine Keihin jets...the 150mj will be ok with that pipe, if that arrestor is removable it probably needs a de-carboning...
It wouldn't hurt to buy a few extra jets around the size you need...
