Water pump seal
How do I take an old water pump seal?
What are you talking about. Do you want to replace it?
Ya I'm replacing it
Well if its just the impeller pump cover thats easy just drain the coolent and its a o-ring type gasket. Are you getting coolent coming out of the weep hole?
I just removed mine half hour ago. Use a screwdriver and pry it out from the impeller side. Do not let the tip of the screwdriver touch the case, or the shaft of the screwdriver touch the impeller gasket surface when prying or you will do some damage. Remember to apply Suzuki THREAD LOCK SUPER to the outer surface of the new seal before you install it into the case
Edited by GWaddCustoms
