YZ125,250 VHM, Phathead, BUD performance cylinder heads !
Thinking about purchasing a performance cylinder head for my YZ. It seems like an easy performance upgrade to a 2 stroke. All you have to do is replace the cylinder head.The head can be customized with inserts  to give you a different compression ratio resulting in a more power, the kit requires you use a higher octane fuel with high compression head inserts !
Kits costs approx $250 anyone know if its worth the money !
Any thought to just setting the squish? Cheaper...
I agree just buy a head off ebay. send yours and the new one off to set squish and compression one for pump one for race....should save a few bucks....
Check out the ones from yzstuff.com too.
Edited by nickmell
Does someone know the spec of the VHM cylinder head for yz250?
I know the squish is at 1.5mm and with different volumes.
But I would like to know
1) the WIDTH of the squish band
2) the ANGLE of the squish band
thanks a lot
