2014 YZ450F Stock Valve Stacks USA Model
May come in handy to someone one day..
Forks
BCV, Bleed Valve, Comp Low Speed stack whatever you like to call it:)
14x.30(2)
12x.30
14x.11
18x.11
20x.11
22x.11(3)
Base Valve
32x.15(11)....yes,that's .15
30x.11(3)
28x.11
26x.11
24x.11
22x.11
20x.11
18x.15  yes,.15
17x.30(3)
baseplate
MV Rebound  (some more .15`s and even 20`s)
20x.11(2)
18x.11
11x.11
18x.15
16x.15
14x.20
13x.20
12x.20
11x.20
10x.20
16x1.5 base plate.  1.2mm bleed holes in pistons and .25mm feeler gauge measured float.
MV Compression
20x.11(4)
17x.11(2)
12x.11
10x.20(2)
12x.30
15x.30
17x.30
Note: fork now has 500mm springs. Maybe now the plastic spring seats wont break!
Shock
Rebound
40x.20(5)
25x.10
40x.30
38x.30
36x.30
34x.30
32x.30
30x.30(2)
28x.30(2)
26x.30
Base Plate
Compression
44x.20(12)
37x.15
44x.20(2)
40x.20
38x.20
36x.20
34x.20
32x.20
30x.20
28x.20
26x.20
25x.30
base plate
  • Like 2
Thank you ! Does for me, lets me crunch out some numbers before having to pull all the suspension apart... Again Thanks !
Edited by Biscuits
Forks look almost like a sx setting
No problem Biscuits!
and 10 4 Mog:) You got that right!
The 14 is not crazy soft like the older models that used to ride like a "seesaw"!
I liked the older ones lol , the 06 I had was nice
Oops, I meant the 10-13 yz450`s. And yes, the 06-09 stuff was niiiiice:)
Hi Mike !
How many coil fork spring has?
Edited by babilon
26.75 active coils Babilon
Hi Mike !
