What a pleasure to work on a almost new DRZ434 SM (SSW worked motor already)... Clean, well maintained and rider wanting to do only the best in add ons, MODS, and all the reliability fixes prepping for a long upcoming ride.
 I really don't mind helping out the cash strapped rider that just needs it fixed.... But I really enjoy building with the best parts available.
Install IMS gas tank with manual petcock
Install and wire F&R LED blinkers, Electronic flasher and Edge tail light using OEM connectors sourced from Japan.
Install Kick start kit
Install S kick stand
Install IMS pegs
Oil Change
Free Power MOD
Bypass Kick Stand Switch
Install 4 circuit Painless wiring ATO fuse panel
Install Volt meter
Install GPS and wiring
Install Headlight bypass using Highway Dirt Bike brake perch dual switch
Nice project.....Would an FCR39MX fit ok with that IMS tank ?
Thanks. :smirk:
That's very thoughtful of you Eric. :thumbsup: ...maybe shoot some progress pics up for board to plunder upon...lol
Nice job to start the day with:)
Choose not to work on it tonight, long day on the range and I've had a few beers.. :devil:
Monday I'll dig in and will post a few pics once it's done (wed, still waiting on parts)
Plus one on Pix
O'k just ordered one !  :D
Somethings are just a pain..
What size are DRZ bars??? Why that depends on model of course..
ok then,,, what size are DRZ400SM bars? Why that depends on year of course  :thumbsup:
Those that know the bike, know this..
Those that own one DRZ and don't know all the changes,, looking at the catalog.. well IT SAYS THEY FIT... :rolleyes:  Unless of course you have a later model SM... then you have 1 1/8 bars.... and buying 7/8 Cycra CRM Hand Guard kit wont work so well. :banghead:
Leaving the owner four choices
Dont install.. not really an option
Buy the correct clamps.. Plus $48 and shipping time &$
Return the whole kit and buy the correct kit ....shipping time &$
Ask the Owner of Marquez Racing to bore the 7/8" clamps to 1 1/8 "  :cool:  so we can get this project done and out the door.
I choose  option #4
Just like to say I'm glad someone stepped up and took Victoria's $20K to build her boyfriends dream DRZ. :jawdrop:
My Marquez :cool:  we salute you. :devil:
You all know I'm just joking. :rolleyes:
:thinking: ????????..Could it be Vic's bike..?.. :eek:
Nice Work E
Yeah , what happened to VIC ? :thinking:
That really looks like fun! You are a generous person to do that for someone else. :thumbsup:
I don't like unfinished jobs....  :thumbsup:  My work quote said "Install Hand Guards" .. not " install Hand Guards if it's easy and requires no MOD's"  ;)
IMS Tank installed
As is common, some fitment of the mounts required.. just a few seconds with a air die grinder is all. Hand file would have done just as well.
EDIT: I spoke too soon.. I had not installed the lower front mounts when i typed that above.... What a fricken pain in the ass ...the tank holes and threaded fastener to be attached to were off by a long ways ... The one thing I hate about all the aftermarket tanks is the initial fitment...Only my IMS Team tank went on smoothly all others i've installed, couple of dozen over the years, all brands, are a pain.
Electronic flasher installed
Pins removed from the OEM flasher/relay combo, then matching bullet connectors added to those wires and the flasher mates.  Ground wire was placed under the lower center dash screw.
Edge2 taillight installed along with DRC LED blinkers
Will make a sub bracket today to mount the license plate.. as the plate holes do not match up with the holes on the plate holder.
Free Power MOD done...
Side stand switch bypass completed
KOSO voltage meter installed and wires run, but not yet connected,, waiting on the fuse panel.
4 Circuit painless wiring fuse panel installed  , with hot lead on a key on switched relay
Had to mil down some of the fuse box as it was just too large to fit where I wanted it..
License plate bracket made, and fitted
Dual switch perch mount installed and wired up.. Low beam bypass now ready at the push of a button.
Second position is for a future add on set of lights.
KOSO voltage meter wired to the fuse panel, reading actual battery voltage
And now we wait for USPS delivery tomorrow in the hope my Eastern Beaver order gets here
Very nice,  your work is nice and clean/profesional,  looking forward to seeing this DRZ completed.
This is not your bike?
This is not his bike ... M8
  • Similar Content
    • By Teamhonda1992
      I bought a non-running 2015 Crf450r from a guy who said that the local honda shop said it needed a new ECU. The bike has maybe 20 hours on it tops it is spotless. I changed the ECU and got nothing. Started to dig deeper and found out it had no compression. The nikasil (however it is spelled) had completely flaked off the upper third of the cylinder. Replaced the cylinder and put in a new piston still nothing. Swapped out the fuel tank in case the pump was bad, nothing. Checked all electrical connections and everything looks good. After a bunch of headache, finally got the bike to start by spraying starting fluid in the cylinder AND applying an external power source to the fuel pump. Once the bike starts up, it idles fine, revs fine, etc. However, it WILL NOT start without the external power source. Since finding this out, we have replaced the stator and tested all of the connections going to the ECU for a break or bad connection. Still nothing without the power source and starting fluid at the beginning. I am lost at this point as far as where to look next. Any suggestions or tips would be very much appreciated.
      read up on past posts and got busy testing my buddy's '00 drzS which runs it's battery dead when ridden.new rectifier and all connections checked over(so he says) so i unplugged the three yellow wires from the stator that go to the rectifier and probed them with the multimeter (red) and grounded out on the motor(black) and got plenty of resistance.what do we need to do next? what does the parts man need to charge us for this time?
    • By cgifool
      hi there, I recently bought the ricky stator ltz400 stator after having seen a post confirming that after soldering the old harness on the new stator worked.
      unfortunately, after I completed my work, the bike no longer starts. im really not sure where to start. I unplugged the connector with the blue/green/white/grey wires from the box under the seat, and managed to test the blue/green resistance at 0.52 on whatever resistance scale my meter was on. I did not test the black/white wires.
      the battery is fully charged, the main fuse is intact, the starter runs strongly, the bike just doesnt fire.. it ran fine before taking it apart, so im sure i've messed up the job somewhere along the line. Im going to recheck to make sure I didnt reverse some wires along the way. That cloth insulation is annoying, I finally ended up using an exacto knife to carefully trim it off.
      David Mitchell
      Austin, TX
      01 drz400s
      78 r100/7
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By SndyRds
      For my 2001 XR650R
      Searched around, and found some information, but I need a little more.
      Looking at an after market tank, which works best? I plan to go with the red, and would like it to match the OEM color. I will be running a Scott's Damper, probably. Any clearance issues?
      What range are you averaging with a 4.3 gal?
      I have considered the seven gal behemoth from acerbis, though it looks too wide for my tastes. Though extra fuel is good, but adds weight. Yes I know you can run it low, so why not a smaller tank?
      I've had natural colored tanks before, but I'm not racing so no need to check level, on the fly.
      Pictures would be great!!!
      Anxious to find out what the BRP heads are using, and what works.
