2003 Suzuki DR-Z125L...
I was attempting to change the oil, when I realized I had removed the wrong plug, and a spring and a bullet shaped plunger fell out into the oil drain pan.  I've tried to find a parts diagram, that would show how it's correctly installed.  I would guess the plunger goes in first, then the spring behind it, then the plug I thought was the drain plug.  This would keep tension on the plunger.  Does anyone know for sure?  Any help would be greatly appreciated!
I simply cannot thank you enough for your help!  I suspected this was how it went, but wanted to know for sure, before I installed it and took the risk of ruining something or causing internal problems.  I greatly appreciate your help!  Thank you and have a great week!
