Piston/ring replacement now I have issues
Bike ran good before this, but I knew I was burning some oil and it was getting up there in hours.  So I pulled it apart put a new weisco piston and ring set and oem headgasket in.  The cylinder looked good, factory cross hatching was  visible, but I didn't hone or touch the cylinder (should I have?).  Put everything back together and it doesn't want to run, after a lot of kicking I have got it to run but doesn't want to stay running, also sounds more chattery than before.  I talked to someone that's more experienced with this stuff, and they said maybe I should have had the cylinder honed, is this right?  Havent taken it back apart yet, but think Ive caused any damage to the new rings or piston? thanks for any help
Did you clean the cylinder with hot soapy water and a green scotchbrite pad ? Usually if the
Cylinder looks good that's all that's nessasary for the most part , is it smoking when it's running any worse than before the teardown , all that chattering could just be your decomp not installed right or something , I'm by no means a professional just thinking out loud !
You likely have the cam timing off a tooth and/or you didn't relieve the cam chain tensioner's tension before reinstalling it.
And yes, you should have scotchbrited and then cleaned the cylinder. If it's only been run very briefly, you could disassemble it and fix the issues.
Edited by Eddie8v
Yes its only been run very briefly, as like I say it didn't even want to run.  When I disassemble it is there any signs to look for on the rings that they may be damaged think ill be ok re-using these new rings or should I buy another set? thanks for the replys
I am sure they're fine, just take a look at them to be sure the outer sealing surface is ok.
Not to hijack but scotchbrite does what exactly?
It's aggressive enough to remove any deposited piston aluminum from the cylinder wall's Nikasil crosshatch, but won't hurt the hard Nikasil.
Ok sounds good I might get a new set of rings just for piece of mind. Think red scotch brite is too aggressive? Just that we have lots of it at work, otherwise I'll go buy some green/ blue stuff
Not to sound like a dick, but if your having problem getting the bike back together correctly, I'd get someone who knows whats going on working along side you, before going back inside. I wouldn't take it apart again just for a hone. You won't do damage to the new rings by not honing the cyl. At worst the rings won't seal as well as they might have if it were done correctly.
These bikes aren't that difficult to work on. As easy as they are to work on, they're even easier to eff up which can get expensive.
Take a look at cam timing before tearing it all the way down again.
Did you relieve the tension on the cam chain tensioner?
Don't think I said I was having trouble getting it back together
Like others have said.  Check the cam timing.  Just did a similar piston and rings job and didn't do any honing or scotchbrite work.  Started up and ran great first kick.  Did take my time watching some youtube videos and making sure we got everything right.
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
