ttr 125L bog
My ttr has a bog only when trying to hit the throttle hard during slow speeds...happens in any gear..just cruising along it doesnt happen..it is only 30 degrees out..could that be why...should i go up to a 112.5 jet?....specs:
Snorkel removed
new spark plug
valves in spec
jetting 110/17.5
oem exhaust
Your jets are fine.
These bikes were made without an accelerator pump carb. You can always get one to bog, even when perfectly tuned. You just have to roll on the throttle.
