2005 KTM 525EXC Carb
Pulling off my carb to clean today. Before any disassembly as I was pulling throttle linkage cover to disconnect as small spring with a brass bushing dropped. I will attach picture. Again this was before any disassembly. Any help identifying is much appreciated. Runs fine after reassembly with out whatever this is im puzzeled
Edited by mb5885
that goes on the top side of your slide- directly on the top of the needle  head then a allan head screw to cap it and hold the needle seated
Thank you
