1989 YZ125 New OEM piston to cylinder clearance and service limit numbers?
I have a just what is listed and going to bore up to 56.25mm or 56.5. I have read that .005" is the service limit, wich I am over at .008". I would like to know what  the oem new spec for the piston to cylinder clearance so I can bore and hone to it.
andy
Hey do you have an extra bottom end for this bike! I'm in desperate need
I don't, sorry, this one is my first and only 2stroke mx, and the bottem in is solid. I wish i could help.
It got the spec from Wiesco. 002 new and .005 service limit. I bored on my lathe, then finished to 56.5 with a hone. The clearance ended up as .0025, close enough for a home bore job on a lathe.
