Oil in airbox -
1993 XT 600e: 6,500 miles I finally changed the air filter. Was really plugged and noticed oil in the bottom of the airbox, quite a bit. Is anything damaged? What to look for now. Thanks
You're likely OK . The motor oil may have been over filled at one point . Check the crankcase vent tube for any blockage . Particularly in the nipple on the case . Pull the tube so you can see into the transmission through the nipple . Most times that's where sludge / condensation cream will build up .
could also be that the last person to oil the air filter used motor oil becaus it doesnt stay on the foam over time it runs down to thebottom of the air box not sure how much oil you are talking though.
