Leaky exhaust
What kind of seal do you use between the header and muffler?  I've got a air leak on the exhaust of my 08 kx250f...
Iv never had an exhaust that had a seal there. The head pipe goes into the slip on. If it's an exhaust leak it's your head pipe or your can needs repacked. Is it back popping on decel?
09 yfz450r
09 kx450f
Edited by dirtsurfer614
I just put on an fmf pipe on my bike and they recommended high temp silicone. I used perma gasket black and put a thin layer. No leaks.
Yeah its popping on decel.  I like the silicon idea.
I didn't use anything on mine and it doesn't pop.
09 yfz450r
09 kx450f
The stock pipe has a gasket/seal that goes into the silencer side which makes it fit tight over the header so the clamp can hold it and not leak.
I dont use aftermarket silencers so not sure about them.
My akrapovic slip on has a composite collar that slips over the head pipe and it was an SOB to get it to fit right.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
