Handlebar installation help needed
Ok so, I'm installing my new pro taper se cr high bend handlebars. I'm stuck at a point where I can't quite get the cover that covers the throttle cable on tight without making it so the throttle won't turn back after turning the throttle. Did I screw up with drilling the hole for the throttle tube? Or possibly do I need to put more grease inside of the cover?
Anyone getting back to me as soon as possible would be much appreciated.
If something is binding then grease isnt gona fix it.  Sounds like something isnt installed or fitting properly in your throttle.
  • Like 2
I finally got it to work, not sure what it was that was causing the throttle to stick.
  • Like 3
It needs to fit together right.  The screws need to be tightened evenly. The moon and stars need to be aligned just right too sometimes.
Glad to hear you got it fixed.  :thumbsup:
  • Like 3
