2003 YZ125 shock to swing arm linkage
will a suspension linkage from about a 2006 yz250 fit on a 2003 yz125? I'm looking at an aftermarket linkage. thanks!
Here is my post. I talked there about 17D(09-YZ250F).
http://www.thumpertalk.com/topic/1075550-09-yz250f-04-yz250-front-and-rear-suspension-swap-s/?p=11465636
But there is the same problem of bearings and collar size on 1C3 connecting rod. 17D and 1C3 use same things.
It will be helpful for you if you mean the linkage as the connecting rod.
