piston scuff
Any body got any ideas what might have caused this was running great then boom it slow down and lost all compression, engine was not overheated
and had water I checked the cylinder for heat when my son came in off track cause right after it happened , the piston had 48hrs, it is on the intake side .
I am going to check water pump why I have it apart . I am a 2 stroke guy so if it was a 2stroker I know it would have been lean the piston seem good on top
little black all over and the plug had good color. any ideas would be help full
If, you know for a fact bike is not too lean, and your son doesnt abuse the motor, then several things could have happened.. dirt deposits slipped into cylinder, rod bearing went and piston had too much play, or yes, cylinder head warped and piston snagged on cylinder wall. Or rings were worn out at 48 hrs, gave up, then rings snagged cylinder & KABOOM
Check the small end/wrist pin for play. My guess would be the ring got snagged
Ac, where you been buddy? I hit you up on the Pm board days ago
Sorry. Been busy. Just finished putting the rmz290 together with the vortex and the 2012 magneto. Starts and runs great. Going riding. Talk later
