Xr 400 head temperature
Hey all, I was curious enough today to ask what is the normal head temperature for a 96 400r? I'm putting a vapor trailtech device on my bike, and I wanted to know what the average head temperature is, just to make sure I'm not running to hot.
I'm not sure what's normal but mine runs between 140 and 170 degrees.
I didn't like the idea of putting it under the plug so I put it in front of the plug under a head bolt.
How did you wire up your tachometer still having issues with mine.
I used the head bolt
Too. I converted to DC to avoid tach issues. The only way I could avoid the tach issue while I was AC was to disconnect the power and run on internal battery
Please excuse grammatical errors. Sent from my iPhone using Thumper Talk mobile app
I wrapped the wire around my spark plug cap wires about 5 times and it says I'm idling at around 4000 rpms, which is completely wrong.... Although it does idle a little high it's still wayyyyyyy off.. and I'm actually thinking of converting my bike to dc instead of ac ( just to run hid lights)
how does converting to dc help? I wanna convert my bike to dc but I don't have the money. What's your setup? What did you get to run dc? I'm trying to get some ideas
I'm running DC aswell running trx wiring loom as I have electric start fitted. But still get around 4000 plus rpm but it's a stable. One day I'll get around to trying different things. I had tried straight into the coil +ve. I have been told to try the earth but can't see that working but will try one day.
To convert your bike to DC you need a battery and a voltage rectifier. DC provides constant energy. Ac switches back and forth. This causes your device to flicker on and off at low rpms.
These things count the number of sparks per given time. XR's throw spark every engine revolution thus you might get twice higher RPM reading. Most four stroke engines throw spark once every two revolutions.
Edited by messat
