My idle jumps up and down about 200 rpms everytime I check its never the same. It'll be at 1500-1590 then next time I check itll be at 1300-1400 so ill turn it up then its at 1700. Its a never ending cycle. Is this normal?
make sure carb is clean , float height is correct, and maybe replace pilot jet, they are so small it s tough to get them clean.
An unstable idle is typical of a carb with a worn slide. It's particularly a problem with flat slide carbs like the TM models that are used on off road DR models.
