to much oil
Did a oil change on my 06 crf450 well after I got it all changed looked into the looking glass and It was all the way past the high level mark. Should I drain some out or just leave it, do not want to run the risk of messing it up
Did you measure?
The sight glass is notoriously inaccurate even if you follow the 3-min warm up, 1-min cool down, level surface rule.
Edited by TheKoolAidMadeMeSick
Did you measure?
I did and then I let it warm up then sit and it still looked a little low, so I added some it was lookin perfect till I kick it over a few times then It was to full
Edited by 209mark123
