84 tecate couch problems
My tecate power has never been neck whipping, but never felt like clutch was slipping. Have only maybe 10 hours time on it since I've owned it. Well I broke a clutch cable and replaced it. Then return arm seemed to be sticking so I took it out n greased it. Then was ridding and felt something sort of slip. Now motor runs but when I put it into gear shifter may stay down and when I pull up on it, trike won't move. Any ideas.
You may have to take a look into the clutch case and see if the shift spring is toasted or some other component.
