2006 RMZ250 oil plug(s) is there 2? Seen several answers
So I have always just drained my main (bigger) oil bolt but I see people saying I need to remove both bottom bolts, then I saw a youtube video showing a bolt on the side of the case. I am confused...
I heard there isnt much oil in the transmission case so just draining the main bolt is really all thats needed. Just looking for an answer I cant find a thing
Yeah there should be 2, I believe the bigger one is a 14 mm and the smaller one is a 12mm both should be easily visible when looking under the case. The bolt on the side is for checking the amount of oil you have since there is no sight glass.
I do have a sight glass and there are 3 bolts...
Edited by taymag
