XR650L - riding today (road) and started idling at 2500rpms
Hi Guys,
I bought a 2006 XR650L and it had about 5600 mi's on it.  I put almost 200 already on her, road riding.  Today she started idling very high and then I would ride for a mile or so, come to a stop and the idle would go way down (almost try and die),  I would give it the ever so slightest amount of throttle to keep her from dying and then the idle would jump back up to 2500, the throttle response seemed high while under way and seemed to work on the upper end.
Any suggestions where I can start?
Things I have checked - downloaded a shop manual for pics of the carb so I can know whats what.
- bottom drain line off of carb had a little gas in it when I touched it with my finger tip
- Other train lines or what they call breather tube seems okay (open on the end).
- All of the cables and the needles are tight (I can see it on the bottom of the carb).
- it was about 40 degrees today ... could have affect it?  I am in Utah, live on a hill and regularly drive down into the valley, seems okay though, has been running perfectly.
Suggestions?
Tim
Drop you idle as low as it will go with the idle screw, then raise it back up with the fuel screw
