2007 DRZ Will only idle
Previously swapped plugs, the old one was orange spark. New one was giving blue spark.
Battery is dead now so charging it. I have tested the charging system and most test seem to past. Once I can start again I need to verify if it the battery is charging which is the last test I was unable to perform.
I am leaning towards possible bad stator. I may pop off the cover while it is charging to see if it looks like some of the fried ones I have seen pictures of.
I have no experience with dodgy stators but your running out of options, good luck.
post pics, since we cant see anything, and were all going off descriptions...maybe well spot something your over looking ?
what did you clean the carb with? the o-rings dont like carb cleaner
Edited by 707LAKE
The carb is brand new. I just replaced yesterday with an FCR I got from TT. I just pulled the stator cover and the stator doesn't show any obvious signs of being burnt up. I will try posting a pic of the strator.
