Need Help. 2001 YZ 125 Shock Bearings Dont Fit.
Hey all, I'm rebuilding the 2001 YZ125 I bought recently. There was a ton of play in the swingarm and linkage so I decided to replace all the bearings, only problem is, the bearings don't fit. The only think I can think is that I have I different shock in the my 2001 frame. Anyone have any thoughts?
These pictures are of the upper bearing that was sent to me, against the upper bearing that is in there. There is no amount of heating or freezing that would get this bearing in there . . .
This is the lower shock bearing against the upper shock bearing hole . . . seems like it would fit perfectly.
These last two show the lower shock bearing that was sent to me vs. the one in there, there is way too much room for the one sent to me as you can see.
Any ideas? Do I have a completely different year shock in my bike, and if so which one? Any help is appreciated.
OEM bearing or aftermarket?
I dont have a solution, but Im having the same problem so I thought I could help with what Ive learned so far.
I bought a 2006 YZ250 with an unknown history and some parts of it have been pretty well neglected. Im trying to square it away.
I too ordered a lower shock bearing after finding this junction very loose. The All Balls lower bearing kit shows fitment of 2001-2014 YZ's. My problem is Identical to yours. The OD of the new bearing is way smaller than the old bearing, and obviously of the ID of the lower shock. I also have an 06 125, without taking measurements, the shocks look very much the same. My first thoughts were maybe someone put an ebay special on there from the 90's?? I took measurements of both lower bearings that I have but do not have them in front of me at the moment.
Id love some help on this as well. I may just have to try to get a dimensional bearing from a bearing shop.
aclimbatize, are you sure your bike is an '01 and not a '00?  They are very similar visually, but it might explain you shock bearing issue
Well, honestly, I think this is a Frankenbike. I checked the VIN and the frame seems to be an '01 based on the things I've read, but the engine is a 5-speed which I know were '02-'04, the linkage has threads where the bolt goes through the bottom shock bearing like '01 and earlier bikes, and the bearings look nothing like the ones pictured in the manual or parts fiches for an '01 or later. I ordered a set of '00 upper and lower bearings . . . we will see how that works out I guess. I'll update here when I get them in hopefully later this week.
I also managed to completely hose the dogbone section of the linkage trying to get out seized bearings so I ordered a new one off ebay (with no bearings in it, easier to press new ones in then get out seized older ones).
Been an interesting project so far can't wait to get everything back together and finally ride!
  • Similar Content
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
    • By fiat2nv
      Hi all, First post here. I need some help.
      Ive just bought an 05 yz 125 for a good price but it needs some work. One of the forks has some pretty severe pitting of the chrome on the stanchion towards the bottom near the brake caliper mount.
      Ive found a pair of good condition forks from an 04 yz250 for a very good price, from the research ive done its seems that both the 04 & 05 forks are 48mm but are different, with the 05 fork regarded as being better than the 04, but not as good as the 06 + sss forks.
      Im looking for the cheapest way to get me riding, Will I be able to make the 04 forks work with my 05 triple clamps, brakes, wheel, axle, spacers etc? If not does anyone know what hardware id need to make it work?
      Finally, as a last resort, does anyone know if i could swap the stanchion from the 04 fork into my 05 forks?
      Thanks, Andrew
    • By idratherberiding
      I bought a 2006 YZ250, have ridden it 5 times.  It needs some tuning, but I am not sure I'm keeping it so don't want to spend much on it.
      Has fmf gnarly expansion chamber and turbine core silencer.
      I ride about 1000 feet above sea level.
      I'm going to clean the carb and check the jetting.  What is a good jetting for me?  85 main jet?
      Also check the reeds.  Is there a big difference between getting aftermarket reed cage and reeds or just getting a cheap aftermarket set of reeds that fit the stock cage ie.  Boyesen Power Reeds?
      The other things I'm going to do is permatex all the joints in the exhaust system and a compression test.   It was 220psi 5 rides ago so I'm guessing itll be fine.  Its bogging a bit but I'm thinking its carb and definitely exhaust joint related.
      Let me know if I'm overlooking anything that could make the bike run crisper and more bottom end without throwing much money on parts
