dies as soon as i shift to 1st gear. Please help!
2000 yz 125 dies as soon as i shift to first gear...its like im green horning it but it does it before i even let out the clutch.
clutch dragging? try reving it when you shift into gear. WTF is green horning?
green horning is when you're pulling out and you let out the clutch too fast and it dies.
Maybe adjust the play in your clutch cable. Try starting on a hill, get a rolling start and put it in gear. with the clutch in give it a little gas, if the bike still wants to accelerate, you either need to adjust your clutch or replace it.
Edited by desrider891
The last time you rode it, was it hard to shift or get in to neutral while stopped?
I've never rode it before. I just bought it, put new piston and ring in, rebuilt the carb and changed water pump seals.
Take the clutch cover off and look at the basket. I'd bet it's really notched.
When I had it off I don't remember it looking like that
i guess i also should have mentioned that this bike has set for about 8 years or so before I got it.
If it runs fine and dies as soon as you shift to first with the clutch still fully pulled in it I would think it has to be a clutch issue.
Try this - open the oil filler and look down there. Can you see the clutch basket? Is it notched like the above used and abused basket?
If it's been sitting for so long, you might want to run some kerosine in the tranny - Warm the engine, drop the oil, put half a quart of that stuff in there, start it up and let it run for about a minute. Drop it, put crappy oil in there and ride it for a few minutes going through all the gears. Replace with more crappy oil...do it till it's all nice and clean.
Option 2 - Take clutch cover off, take clutch plates out, check for warpage, if warped, replace. Go ride.
clutch basket is fine. just took the cover off. guess ill take all the plates out and hope I don't screw it up.
If it sat for that long, the plates may be stuck together.
No clue what this is but behind that nut but on the left side it's bent up against it. Don't have a socket big enough to fit that nut either so I'm sol
Defiantly no grooves in the basket
:lol: That's a retaining washer, it keeps the nut from spinning. You shouldn't need to take that off. Post some pictures of the basket, inner hub and clutch plates.
Also, I'd get a manual...
Clutch plates don't seem warped
I have a manual downloaded.
ImageUploadedByThumper Talk1395418399.470457.jpgImageUploadedByThumper Talk1395418423.338986.jpgImageUploadedByThumper Talk1395418448.755376.jpg
Should I clean the oil off the clutch plates before I put them back in?
In your second photo, your basket is notched pretty bad. Maybe time for a new one. Post a pic of your plates too.
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
