Brake rotor issue
I got a 96 rear rim for my 96 cr125 and the brake rotor is to big in diameter so the axle won't go through the caliper bracket... Do different years have smaller diameter rotors or even one from a different model??? Help
??? More explanation needed.
Ok just realized the rim is off a 98 not the 96 I was told. The rotor is 240mm and when it's on the rim the caliper brack won't line up for the axle to go through. I need a smaller bracket but I don't know what year I should be looking for
Just looked up some aftermarket rear rotors for CR125/250. Here are the applications, you can tell what year a change was made to the brakes.
1989-1997
1998-2001
2002-2007
My guess would be you just need to put a 96 rotor on your 98 wheel, or get the 98 caliper bracket
Dont take my word as fact though lol, I always use the OEM parts microfiche's to cross-check part numbers. looking up the hubs and calipers / brackets should tell you what was changed
87-97 cr125, 220 mm
98-07 cr125, 240mm
87-96 cr250, 220mm
97-07 cr250, 240mm
87-01 cr500, 220mm
You could easily upgrade your rear rotor on your 96 with a 97-99 cr250 caliper bracket, or 98-99 cr125 caliper bracket.
Direct bolt on.
