Help me ID this carb part
OK, Bike is an 07 yz 250, the part I need is the part that holds the throttle cable and is removed with a 6mm socket when accessing the needle. Its not really 100% clear on the fiche but the one I believe I need is labeled as "holder", part number 5HC-1426-00-00. Thanks in advance.
yes that is the part you are looking for. Just to let you know it does not come with the little spring and collar. You can use you old ones or buy new ones.
Thank you sir
