Larger grip recommendation
Have any of you guys installed larger hand grips? I just took my first ride and they feel a bit smaller than I'm used to..
I like my pillow tops .... the stock ones are thin ...
Yea the stock grips are junk, any aftermarket grip will be an upgrade.  I also like the protaper pillow tops, they are sweet, feel great, and have a tad bigger feeling than the stock grips.
yeah, absolute rubbish, worst part on the bike. Odd shiny plastic/rubber stuff. Maybe they're what they use on some scooterbike.
Do all of the above ones for on the sock bar?
Yes. Almost all bars are 7/8" in dia. where the grip fits. There are larger dia. bars, but usually made for Harleys etc..
Personally, I can't stand pillow-top grips. Found them no more comfy than stock, plus they're flimsy and rip easily.
The Progrip 714's actually help reduce vibration and fit bigger hands better.
Edited by humbug
I have a set of grip puppies fitted over my stock grips on my GS. They are mainly for touring comfort, however, they fit all bikes (with a regular sized grip). I guess they wouldn't be smart on a dirt bike as they will tear if caught on rocks etc however no probs for commuting. They are superb on my GS though!!
oh, and I have pillow tops on the CRF...they're lurvely!
Edited by dturk
What is the purpose of the "wire" groves on the 714's? Why would you want wire on you grips..?
It is grip wire ... real thin and is there to keep them from slipping .... all the racers do it ... I don't think we need to ... we can always shoot some super glue up in there when we get home ... but a racer or long adventure traveler might want it.
it's safety wire, same thing used for safety-wiring bolts.  you can get grip glue, but i've never needed it and i don't know why the racers don't just use it. maybe some of them do.
PS: they say the pillow-top grips get sticky in the sun. (you know, that big round hot thing in the sky, that you see in the south.)  :D
Annoying sticky or just a bit tacky? I like the idea of bigger more push grips and so far the pillow tops are winning my search
just a little tacky ... I like it tho ... but I have always liked grippy grips ...  :thumbsup:
If it was on a street bike it would be annoying ... pillow tops are off road grips.
I also spend a lot of time on the street too .. they are cheap enough that if you do not like them you can always switch them out for something else.
Perfect. I'll order some too. Do you need grip glue for them (or hairspray...) or good enough on their own? Just need to build up ages more parts to get free shipping ;)
I ride with gloves and like the pillow tops since a death grip isn't required.  They help me with some hand numbness issues also.
mine were put on with spray paint ... the left will slip when it is above 95 out so I need to inject super glue or do the grip wire thing or both ...  :thinking:
My pillow tops arent sticky.  Maybe just a slight tacky/grippy feel, but I quite like it.  I suppose if you let them sit in the sun a lot maybe they might get a little sticky?  I wear gloves most of the time unless im just going for a quick ride around town or taking the bike to the car wash.  I think keeping them clean helps too.  When I take my bike to the car wash I hit the grips with the pressure washer, it gets the grime and discoloration off from wearing gloves on them.
I did glue mine on the stock bars because the clutch side on the bars is just smooth.  Now I cant remember if I glued the throttle side or not.  The stock throttle tube has all kinds of bumps and nubs molded into it, and the stock grip is molded to fit over all of these things, so I sanded the throttle tube mostly smooth with a dremel tool.  I suppose if you left enough of the nubs sticking up and didnt sand them totally smooth you could get away with no glue on the throttle tube.  I really hate gluing things, but I hate grips moving around even more.  I just got a new set of Pro Taper Contour bars and the clutch side is knurled/textured, so I think you could get away with no glue, which I like.
I found if you clean the bar with rubbing alcohol, clean the inside of the grip with it and install it while slightly damp they slide right on and will move for a few hours.  After a day they stick like glue.  If I have one that spins a little paint does the trick.  Either way I can remove and reinstall the grips if needed.
I like Scotts half waffle. I use hair stray to make them stick and wire to keep them safe. Grips are cheep. So is the wire. Loose grips suck !
PM me your address and I'll send you a pair of 714's for free- No bs.
A friend of mine recently closed up shop and I acquired half a dozen pairs for cheap.
If you don't like them, no loss on your part & could possibly help you narrow your quest for the perfect grip.
As M/C riders, all our ergonomic riding needs are entirely personal-  That's why there's  such a broad diversity when it comes to bars & control products.
Edited by humbug
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit:
      Source: Husqvarna Motorcycles GmbH
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By Daniel Wolfe
      So i've only owned 2 strokes and i now own a 01 KX250 that i've fully rebuilt from ground up and i've enjoyed my time on it even though it's been short i rebuilt it in november so not much riding on the old girl but i've been thinking about getting a honda 250 so i found a guy who wants to trade his 06 crf250 for my KX he says he's more of a kawi guy and wants a KX250 2 stroke to go with his kx yard thumper problem is A i don't know much about four strokes he says the bike has 20 hours on it since the previous rebuild is that a lot for a 4 stroke B i heard the 06 is a boggy valve eating &%$#@! with proper maintenance can this be avoided  i know a lot of people neglect the bikes so i don't know do any of you guys think this is a good deal or should i keep the kx and if there are any other known issues with this year 250 i should worry about or i just don't want to buy something i immediately have to throw a grand into
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
