2006 CRF250R Cam Bucket Issue
Recently, I have taken apart my cylinder head. Removed everything and replaced the valves and valve springs with the kit I got from Pro X. After getting everything seated for the intake valves I went to put on the cam buckets. I applied assembly lubrication and for some reason the cam buckets refuse to go in. Its weird, in how upon disassembly they slid out easily with my magnet tool but now I cant get them back in. Like the cam buckets have changed size? has anyone experienced this or have advice on how to fix it, all advice is greatly appreciated.
Check to see your valve springs aren't out of place the could be blocking the buckets passage
Show me photos
Maybe your new springs are too big, making it a tight fit
Yeah its almost got to be the springs man
Cant be the springs because the original valve spring retainer fits perfect
Check if they are alighned right to fit the buckets
The springs are fine. It almost feels like its hitting the side? Did your cam buckets just slide in or is there some resistance?
Well I've got my 04 apart now and I haven't got my new seals to put it together with. Your bucket could be a tad bit misshaped
Mine were a bit tough last time I had it apart. I lubed everything up and tried different bucket positions (rotations) and kept pushing. They went eventually. I think knowing which was left and which was right helps too. Once they got past the initial bit they slid in normal.
Edited by sjvmtb
Yeah the bore sizes could be different
this^
