1999 yz250 crankcase gasget
GDay Mates
I have a yz250 two stroke 1999 that needs the right side crankcase gasget replaced
Can any one tell me if I need to remove the water pump to remove the crankcase or can I just remove the crankcase alone
Is there any tricky bits that might trip me up or is it pretty easy to do?
Would really be grateful if anyone can help!
As the bike shop tells me they don't work on bikes more then 10 years old, bit of a cop out id say.
On my '03 YZ the water pump is part of the right side case, so it will come off with it. Good time to replace the pump seals while it's off. Also check the pump shaft for wear. Any sort of groove in the shaft at all is an impending leak.
And shops not working on bikes more than 10 years old is not unusual. The one I get my stuff from has the same policy, but will sometimes bypass it for dirt bikes.
Pump should come off with it like olhillbilly says watch the power valve stays in the ramps and may have to turn the bike thru when you put it back together to ralighn the gears
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
