Need help on a 2005 KX250 rear shock
Sorry if this has already been covered. I was wondering if someone could point me in the right direction. I was rebuilding my rear shock. I was at the point of installing my valve stack with all the shims. I had the valve stack on a screw driver in the order I took them off when the screw driver slipped off and my shims went every where. Now I do not know the order they go back in. It was the OEM setup. I know the large steel washer goes on first but other than that I'm lost. Any help would be appreciated. Thanks
It's a stock KYB shock
that doesn't help
you have to provide manufacturer model and built
that doesn't help
Sticker says Kawasaki and KYB. I don't see any other markings except a C487.
Measure every shim give us a list ...never mind I will pm ya.
I did this on my first shock ...a 1995 Ohlins on a KTM.
It will be much easer if you just call me....be glad to help.
Edited by E-TECH
i was talking about the bike,
but - my bad - you already mentioned it at the topic.
here's the data:
Compression
12 - 40.2
28.25
38.25
36.25
34.25
32.25
30.25
28.25
26.25
24.25
22.25
19.3
Rebound
3 - 36.2
28.1
36.3
34.3
32.3
30.3
28.25
26.25
24.25
22.25
Thank you guys my valve stack is back together.
