Passenger peg ball bearing
My passenger pegs were sticking pretty good so I took them apart for a good cleaning, didn't think about the ball bearing being spring loaded and it shot off. Anyone point me in the direction of a new one, and maybe the springs while I'm at it? Thanks
Match for size reference
I got tired of mine sticking all the time tossed the springs and balls in the trash.
Replaced the pivot pin with a 6m bolt and a nyloc nut and tighten it just enough to keep the peg in the up position
.22 bb ?
.22 bb ?
Thought about it, I was gonna go to walmart and check but I think a bb would be too big
Hardware stores often have an assortment of individual balls.  Also a bicycle shop will have many common size individual ball bearings.
Local bicycle shop had two in stock, thanks noble
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
