Linkage Bearing Installation
I was using a socket to pound in the linkage bearings. I bent the lip on the outer part ever so slightly but it made the needle bearings tight inside it. When u put the pin in and turn it its created some resistance. Am I gonna have to buy a whole new kit because of this? It will turn but not effortlessly like it should. I know I should have just had um pres.sed in at the shop.
One of the lips is stronger than the other. That's the one you should have been pounding on. It is the less rounded one. I like to put a bit of lube or WD40 on the outside of the race before getting it in and use a vise as a makeshift press, though I've used the same technique as you in the past with some success.
You can purchase just the one bearing you damaged at any dealership or bearing shop.
Thank u for ur teply. That helps a lot!
I use a couple of different length bolts and good washers, with sockets. Two wrenches, and patience/elbow grease...almost always works as a portable press...and no pounding :)
+1 on using the vise and socket as a press. I just replaced mine a couple weeks ago and it allows you to slowly press them in there. Getting the races out of the linkage arm is another story since you cant press them out. I welded a tab on to them and the heat shrank them enought that you can pound them out alot easier.
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
