Correct Honda front brake for 05 RM250
So I know the hot upgrade for the front brakes on my 05 rm250 is to put a newer crf setup on it. Just want to clarify which one. looking at the master cylinder and caliper off of an 07 crf 250r and after that it says H45 afterwards.
Yes, honda changed the front master cylinder in 07 on the crf's, and from there forward would be what you'de want. If you get the complete setup all you should need to do is use your RM caliper carrier.
Edited by rtv
Or just install an oversize disk with a braded steel line.
